No spark? - Ignition switch wiring diagram
JDL
  • 16,098 POSTS
My thinking is, it may not have anything to do with the starter circuit, which was my first thought. It could be anything that gets voltage from the ignition switch. How long since a tune-up? Are there any trouble codes?
Monday, December 7th, 2020 AT 12:28 PM (Merged)
STEVE ORCHARD
Vehicle has been serviced on a regular basis since it was new, do you think it could be a battery issue, and if it could be why would that be the only wire affected when there are multiple connections on the same starter relay terminal. I do not have a fault code reader for a jeep.
JDL
  • 16,098 POSTS
Your fuel injected, correct? You should be able to get some codes by cycling the ignition switch. You turn the key till the dash lites come on, no further. Cycle key on--off, on--off, on--off, on, then the check engine lite starts flashing, you count the flashes to get the codes. Your looking for two digit codes.
JEEPCHIK
My jeep is doing the same thing except its the orange wire(fuel pump) I replaced the starter relay also and still nothing.I drove it to work, got it in to leave and it wouldnt start. It cranks like its going to start but its like its not getting gas. Also I dont hear the fuel pump turn on when I turn the key. It is a 2 week old fuel pump. Im stumped. And my jeeps 25 miles away in a deserted parking lot. Please help! Lol
JEEPCHIK
My jeep is doing the same except its melting the orange wire. Which I believe is for the fuel pump.I also replaced the starter relay. Still not starting, it turns over like it is going to start but it seems like its not getting fuel.I cant hear the fuel pump kick on when I turn the key either.I just bought this pump 2 weeks ago, do you think there is something wrong with it?
I dont know what else to do, im stumped, and my jeep is far away in a deserted lot.I drove it to work and got in it to leave, wouldnt start. Its been 2 days now.
Please help! Lol
JEEPCHIK
Sorry for the double reply.
RIVERMIKERAT
  • 6,110 POSTS
See if the fuel pump is receiving power, jeepchik. Make sure the tank has enough fuel for the pump to pick up. Make sure it's getting spark, also.
