1996 Jeep Cherokee
1996 JEEP CHEROKEE
125,000 MILES • 6 CYL • 4WD • AUTOMATIC
WILLSSON
car stops running on road, will restart sometime, wont restart most times. have replaced coil pack and fuel pump...
Sep 10, 2010 at 12:11 AM
wont restart most times. Next time it refuses to start do below to determine what's causing it
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
Sep 10, 2010 at 12:15 AM
