1996 Jeep Cherokee
BALBAL_93
  • 1996 JEEP CHEROKEE
  • 6 CYL
  • 4WD
  • 223 MILES
What cause an engine to overheat without the engine light coming on, and is it possible that it can affect your heating for your air conditioning.
Thursday, December 31st, 2009 AT 10:48 AM
  • 109,896 POSTS
Are you sure nothing is frozen in the radiator? Next, you could have a bad temp sending unit. That could prevent the light from coming on. Finally, heat is created by the coolant. If it isn't circulating, you will not have heat.
Let me know and I'll do my best to help you.
Sunday, January 3rd, 2010 AT 4:48 PM
BALBAL_93
The coolant had leaked out from the hose of the radiator which resulted in no anti freeze but thanks
Monday, January 4th, 2010 AT 4:11 PM
