1996 Jeep Cherokee
140,000 MILES • 6 CYL • 2WD • AUTOMATIC
CJPOP1
My vehicle will crank but won't start. I towed it the repair shop and some thoubshooting was done . My computer was checked and found to be ok. I have batt power at the coil but not when cranking. I replaced the coil and still nothing. After towing it back home I'm at square one
Feb 3, 2010 at 11:40 AM
  • 75,988 POSTS
Cranks but no start condition:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Feb 3, 2010 at 11:43 AM
