1996 Jeep Cherokee
1996 JEEP CHEROKEE
KWIK
Electrical problem
1996 Jeep Cherokee 6 cyl Four Wheel Drive Automatic
dash gauges malfunction, waning lights off and on, raio cuts off, info. cluster on-off, display for temperature outside off-on.
Mechanic checked battery, alternator, fuses, relays all fine and did diagnostic no codes.
Someone said it could be body control module and someone else said wiring.
HELP...
Feb 25, 2009 at 1:29 PM
  • 110,244 POSTS
Hi:
It could be the body control module. You can try disconnecting the battery for 10 minutes to see if it will reset. Also, check the ground straps on the body of the vehicle. I believe there is one that goes from the trans to the body that is a common problem with it breaking.
Let me know what you find.
Feb 26, 2009 at 10:23 AM
