1996 Jeep Cherokee
LITTLE B
Steering problem
1996 Jeep Cherokee 6 cyl Automatic
UMM..JUST A LITTLE QUESTION...WHEN I FILL THE STEERING FLUID...IT LEAKS WITHIN A DAY..ANY IDEA WHERE WOULD THE LEAK BE COMMING FROM? PLEASE HELP..
Jun 28, 2008 at 11:20 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:ac554681f0="LITTLE B"]Steering problem
UMM..JUST A LITTLE QUESTION...WHEN I FILL THE STEERING FLUID...IT LEAKS WITHIN A DAY..ANY IDEA WHERE WOULD THE LEAK BE COMMING FROM? PLEASE HELP..[/quote:ac554681f0]
Well there are a few options....
The Pump itself
One of the Hoses
Or the Steering box
What you will have to do to figure out were it is leaking is to clean the engine compartment if it coated with steering fluid. then have someone in the vehicle you under the hood looking at the different areas listed above. start the vehicle and have the person turn the wheel all the way to the right then and then all the way left. Just look for dripping or spraying.
Jun 28, 2008 at 1:09 PM
