1995 Jeep Cherokee wont pass emission test
218,000 MILES • V8 • AWD • AUTOMATIC
KEKEG92
I have taken my truck 4 times and can not pass emission test. i am being told that the hc, and nox is high. so i dont know what to do
Sep 6, 2009 at 9:47 AM
  • 75,988 POSTS
Hydrocarbon failures mean unburned gasoline is passing through the engine and entering the exhaust. The three most common causes include ignition misfire, lean misfire and low compression (typically a burned exhaust valve). Ignition misfire can be caused by worn or fouled spark plugs, bad plug wires or a weak coil. Lean misfire results where there is too much air and not enough fuel, so check for vacuum leaks, dirty injectors or a fuel delivery problem. In addition to these, hydrocarbon failures can also be caused by oil burning due to worn valve guides, valve guide seals and/or rings.
NOX failures are usually EGR-related, since the EGR system is primarily responsible for reducing oxides of nitrogen. But NOX emissions can also be caused by a bad three-way converter or a computer control system that remains in open loop
Sep 6, 2009 at 11:06 AM
