1995 Jeep Cherokee wiper turn signal switch
JOHN H MILLER
  • 22 POSTS
Electrical problem
1995 Jeep Cherokee 6 cyl Four Wheel Drive Automatic
how do remove turn signal switch, wiper switch connected 1995 jeep country tilt wheel .
Mar 6, 2010 at 4:05 AM
ROCKETTEER
  • 8 POSTS
First, remove the plastic shroud from the steering column - this has three Torx (i.e. star drive) screws beneath the column and consists of two pieces.
The turn signal assembly is bolted onto the column with two Torx tamper-proof screws that require a special tool. I recommend getting a small set of Torx tamper-proof bits that can be connected to an adapter handle or electric driver - this will be cheaper than buying a set of screwdrivers.
Remove the two mounting screws and then unscrew the electrical connector and pull it out of the slot.
Replace in reverse order.
Dec 23, 2010 at 7:10 AM
