1995 Jeep Cherokee water temp gauge is pegged
95JGCL
Engine Cooling problem
1995 Jeep Cherokee 6 cyl Two Wheel Drive Automatic
The water temperature gauge is at 260, but I don't see a leak any where and the radiator cap is cool to the touch. There is some moisture below the head gasket area with a little smoke.
Mar 14, 2009 at 4:39 AM
EXTRUDEDCOW
  • 27 POSTS
Is the gauge maxed out from the moment you start the car cold?
If so, it's likely a sensor or wiring fault (sensors around around 20$).
If not, you may have a thermostat stuck closed or an air bubble preventing the thermostat from warming up sufficiently to open. Make sure your coolant is topped off, and replace the thermostat if the problem persists.
Mar 15, 2009 at 12:14 PM
95JGCL
The gauge is buried within a matter of a few miles. I already changed out the thermostat, and it did the same thing. Thank you for your help about the bubble, or the sensor.
Mar 15, 2009 at 11:09 PM
