1995 Jeep Cherokee Water Pump
187,000 MILES • 6 CYL • 4WD • AUTOMATIC
BIGB6410
I bought a new water pump installed it but it is not turning the correct way to pull the coolant through the engine... The new water pump has a R on the blades I was told that is for reverse but I need a pump that the blades turn the opposite way or i need to find a diagram that shows me how to run the belt a different way....Or just the right water pump but the guy at the parts store said there is only 1 listed for this vehicle. I had him check on a 94 and 96 and the results were the same......Please help
Aug 9, 2009 at 8:16 AM
TGFISHEL
  • 52 POSTS
hey sounds like your serpentine belt is not on right try using the link to the left under popular site links ( belt routing diagrams) hope this helps.
Aug 10, 2009 at 11:35 AM
