1995 Jeep Cherokee ruff running
1995 JEEP CHEROKEE
150,000 MILES • 6 CYL • 4WD • AUTOMATIC
CPDJ143
i have this problem, i really cant figure it out, hopefully u might point me in the right direction, the jeep starts, it runs for 10 - 15 minutes smooth, then it get s real ruff idle for 3 minutes, then the jeep will run smooth again for 10 -15 minutes and it does it again, i have replaced the fuel filter, i replaced the cps on the transmission bell housing, i tried a ccoil but it didnt make a difference, any help would be appricated
Aug 7, 2009 at 2:11 AM
DOCFIXIT
  • 18,828 POSTS
Hook up fuel pressure gague observe pressure during rough idle. should be 39-41 psi
Aug 7, 2009 at 2:26 AM
CPDJ143
the gauge goes to just low fuel pressure and thats all the machine says.. not fuel pressure regulator or cold start just low fuel pressure..
[quote:474d4a333b="Docfixit"]Hook up fuel pressure gague observe pressure during rough idle. should be 39-41 psi[/quote:474d4a333b]
Aug 7, 2009 at 3:28 AM
DOCFIXIT
  • 18,828 POSTS
Seems your in ned of a fuel pump
Aug 9, 2009 at 6:58 AM
