1995 Jeep Cherokee "NO" Smog Fail - 1995 Jeep Gra
1995 JEEP CHEROKEE
13,000 MILES • 6 CYL • 2WD • AUTOMATIC
DMC2005
I am getting following SMOG fail numbers:
NO (PPM)
Speed Max Ave Meas
15 508 149 618 FAIL
25 761 144 455 PASS
Everything else was pass.
I don't drive this car much at all. 130K mi. Had small amount of gas in tank, sitting there for awhile. Transmission slipping a bit so not driving much. Trying to hold off on major repairs for now.
Any advice?
Thanks!
Best,
D
Jan 15, 2010 at 7:48 AM
Nox failure -try cleaning out the EGR valve
Jan 15, 2010 at 8:04 AM
DMC2005
Thanks, Rasmataz... I guess I'll be locating the EGR valve next... ;-)
Looking for repair manual....
What do you think about the Smog Pass Additives for NOx reduction???
Thanks!
D
Jan 15, 2010 at 8:07 AM
DMC2005
I read where the Jeep Cherokee 1995 doesnt have an EGR valve? Last was '90 models with EGR???
Jan 15, 2010 at 8:15 AM
Your engine don't have one just checked it-NOX failures are usually EGR-related, since the EGR system is primarily responsible for reducing oxides of nitrogen. But NOX emissions can also be caused by a bad three-way converter or a computer control system that remains in open loop.
Jan 15, 2010 at 8:33 AM
DMC2005
thanks, ras
going to try BG 44K fuel additive... heard of it? supposedly burns out carbon build up...
checking out other additives... to 'de-carbonize'
otherwise sounds like it could be:
- cat
- threeway converter
- 02 sensor
etc...
thanks!!!
Jan 15, 2010 at 8:37 AM
