1995 Jeep Cherokee Please help
100,000 MILES • 6 CYL • 4WD • AUTOMATIC
SHOOTINGSTARS
My jeep will not start and I have changed the starter in it already(just a few weeks ago). What it is doing is, when I put the key in and try to crank it over all it does is act like its gonna start but not turn over. None of the gages will work but the lights and radio still come on. This has happened before but when I changed the starter it started running agian. I am at my wits end, please help me.
thanks
Aug 5, 2010 at 12:58 AM
  • 75,988 POSTS
Cranks but no start condition-do below to determine whether it's fuel or spark issue:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Aug 7, 2010 at 12:44 AM
