1995 Jeep Cherokee oil blow by
165,000 MILES • 6 CYL • 4WD • AUTOMATIC
OILLEAK
95 Cherokee, 6 cylinder
165 pounds compression
Oil found in air filter and tail pipe.
What is most likely? Valve guide seals leaking? Bad oil ring? Or "other?"
Thanks in advance
Mar 23, 2008 at 7:40 AM
  • 75,988 POSTS
Inspect and test the positive crankcase ventilation PCV valve and hose/passages-
Mar 23, 2008 at 7:43 AM
