1995 Jeep Cherokee Lights
1995 JEEP CHEROKEE
190,000 MILES • V8 • AWD • AUTOMATIC
CLARK84635
How do I replace the front side marker lights? I can't get the light assembly out. I have removed the 10mm bolt from the top and the phillips screw from the side reflector.
Sep 13, 2010 at 10:02 AM
MERLIN2021
  • 17,250 POSTS
Are you replacing the fixture, or the bulb? Can you post a photo of both sides? Been a while since I have done a jeep!
Sep 16, 2010 at 6:32 AM
CLARK84635
I have fixed it. Sorry it was a 95 grand Cherokee. I was replacing the outside amber turn lamp. The problem was I could not see the lower screw holding in the side marker lens. I had to FORCEFULLY pry the turn lens down from the marker lens to reveal a totally hidden screw back between them.
Because I had this repaired before your response, and your response still has had no helpful information, do I have a credit to ask another question sometime?
Thanks, Clark
Sep 16, 2010 at 8:20 AM
MERLIN2021
  • 17,250 POSTS
Clark I don't know about the payments, but because you have posted a paid(donor) And you should remain there when you do post another question. Thanks again for your donation!
Sep 17, 2010 at 7:04 AM
