1995 Jeep Cherokee interior electrical components
BENDERCA
Electrical problem
1995 Jeep Cherokee V8 Four Wheel Drive Automatic
I just replaced all of my fuses because I recently messed them up. They are all in the correct place now. After I replaced them, my radio, cigarette lighter, power locks, etc. all don't work. How would I go about fixing this?
Sep 1, 2009 at 6:33 AM
JDL
  • 16,098 POSTS
Check fuse 2--15 amp in the fuse block, use a testlite, check that the circuit is hot, goes hot when you turn on the key. Also, check fuse 6--60 amp in the power distribution center, under the hood. That fuse circuit should be hot all the time.
Sep 1, 2009 at 8:51 AM
