1995 Jeep Cherokee engine stops running
172,000 MILES • 6 CYL • 4WD • AUTOMATIC
WILSONAT
My jeep has 172,000 miles on it and I keep it tuned up, my jeep will stop running as we are driving along, after you get stopped the motor will start right back up. is it the fule pump or is it electrical. I have replaced the fule filter and the injection system has been cleaned.
Oct 14, 2008 at 9:56 AM
  • 75,988 POSTS
Do you have a check engine light? or has come On and disappeared
What you need to do is check the fuel pressure with a fuel pressure gauge designed for your system if its not within specs its not gonna function properly. Might also want to test out the ASD relay this one here sometimes power the coil/injector/s and the fuel pump its avery critical relay-Report back all your findings this is where we start
Oct 14, 2008 at 10:03 AM
