[quote:b51093cdef="Finster0982"]Electrical problem
1995 Jeep Cherokee 4 cyl Four Wheel Drive Automatic 175000 miles
Any one know how to test a cranp position sensor on a 95 jeep 4.0[/quote:b51093cdef]
You might test the wiring circuits to the cam and crank sensors. They share ref voltage and ground. For the cam sensor, the signal wire is tan with yellow stripe, the ref voltage is orange for both sensors, the ground circuit for both senors is black with lite blue tracer. To chek the signal wires, the vehicle needs to cranking, to watch for a pulse. Or you might turn on the key, turn the crank by hand, watch the voltage switch from high to low.
Hey Ras, I guess we were looking up info on the same vehicle, hey man, did you notice, one star, I'm gaining on you. LOL
Dec 7, 2020 at 1:42 AM
(Merged)
