1995 Jeep Cherokee BRAKE LIGHT ON???
1995 JEEP CHEROKEE
MIBUBIO
  • 5 POSTS
Brakes problem
1995 Jeep Cherokee 6 cyl Four Wheel Drive Automatic 181k miles
I changed the rear brakes, and the brake light didnt come on that i saw, then i changed the front rotor, i know they can have one rotor that isnt the right one and theres two do you think that this is what happened?? thanks
Feb 24, 2008 at 6:19 PM
Could be the brake fluid sensor in the master cylinder or the parking brake adjustment.
BTW did you bleed the system? and adjusted the rear brakes
Feb 24, 2008 at 7:17 PM
MIBUBIO
  • 5 POSTS
yeah i did bleed the brakes, and the brakes got hard after i pushed them in but then after about 15 seconds, it got soft again?? any ideas?
Feb 24, 2008 at 7:24 PM
Do you have ABS ? could mean a bad brake M/C again
Feb 24, 2008 at 7:43 PM
MIBUBIO
  • 5 POSTS
yes i have abs brakes, do you think that i have a bad master cylinder? or could it be something else and what did you mean by did i adjust the rear brakes? because i didnt adjust them?
Feb 24, 2008 at 7:49 PM
