1995 Jeep Cherokee Blower Switch
165,000 MILES • 6 CYL • 2WD • AUTOMATIC
CARDUMIE
Where is the Blower Switch on a 1995 Cherokee country
I already replaced the fuse, checked the motor and replaced the resistor.
Thanks
Dec 15, 2008 at 8:20 AM
ANIMALFARM
  • 58 POSTS
Hey, hey, may be your lucky day! I just replaced the Blower switch AND Resistor block on my '96 Jeep Country. The resistor block was located under the passenger side of the dash, right? The blower switch is located on the left side of the heater/AC control panel RIGHT NEXT TO the two control levers that move horizontally - one selects AC, Vent, Heat, Defrost, the other controls the temp. mix. you'll have to remove the instrument panel bezel (3 screws at the inside top), and the steering wheel tilt adjust lever on the left side of the steering column(it unscrews). You'll also have to remove the bottom half of the "cover" that goes around the ignition switch (2 torx screws). The Bezel will come out, although it may feel slightly like you're forcing it - just patiently work it until it comes out. Then just remove the screws from the smaller panel underneath that holds the blower switch, carefully pull out and unplug the connector on the switch. sounds complicated, but I've taken the bezel on and off several times...
Dec 15, 2008 at 11:26 AM
CARDUMIE
Thxs AnimalFarm those were great instructions.
My High speed is working again, I know need to replace my resistor again.
Have a great day.
Dec 16, 2008 at 1:39 AM
