1992 Jeep Cherokee heater control valve
1992 JEEP CHEROKEE
MARKTRAICOFF
Heater problem
1992 Jeep Cherokee 6 cyl Four Wheel Drive 890000 miles
hi, need to know the way to install heater control valve, what hose's go were. I hooked it up the way I thought it was to be but it was'nt right please help I have no heat and it's cold outside. thanks!
Dec 26, 2007 at 1:43 PM
MERLIN2021
  • 17,250 POSTS
If you can't figure it out now, remove it for the winter, you only need it to cut heat in the summer...Should go on the water inlet hose to the heater core..
Dec 26, 2007 at 1:46 PM
