1995 Jeep Cherokee blower position changing
1995 JEEP CHEROKEE
365,000 MILES • 6 CYL • 4WD • AUTOMATIC
GMEANS
can you tell me how to fix a problem with the blower motor changing position when the motor is under load. a/c works fine but jumps back and forth between a/c position and defrost when engine is under load. seems to be a dodge thing. i have two pickups that do the same thing. had vaccum lines checked (cursory) but nothing apparent. thanks
May 17, 2010 at 2:49 PM
  • 31,937 POSTS
Hi there,
I would be checking the actuator vacuum system, get the system check with a hand vacuum pump, i feel that you will soon find a leak, also check the vacuum supply is sound.
mark (mhpautos)
May 18, 2010 at 12:10 AM
