If everything was ok electrically before you did the starter, explain what steps you did to disconnect, then reconnect the starter?
Removal & Installation (Cherokee & Wrangler - 4.0L) Disconnect negative battery cable. Raise and support vehicle. Disconnect battery cable and solenoid feed wire from solenoid. Remove starter lower mounting bolt. Remove starter upper mounting bolt and remove starter. To install, reverse removal procedure. See TORQUE SPECIFICATIONS . Removal & Installation (Grand Cherokee - 4.0L) Disconnect battery negative battery cable. Raise and support vehicle. Disconnect battery wire and solenoid feed wire connector. Remove starter front mounting bolt. Remove starter rear mounting bolt and remove starter. To install, reverse removal procedure.
Jun 20, 2009 at 12:01 PM
