1995 Jeep Cherokee 4x4
1995 JEEP CHEROKEE
174,000 MILES • 6 CYL • 4WD • AUTOMATIC
GREEZY2010
  • 6 POSTS
when i shift in 4x4 it's sluggish driving when i go back to 2 wheel it has a whine/grind noise what could cause that problem
Mar 4, 2010 at 2:17 AM
  • 110,244 POSTS
Can you tell aprox where the noise is coming from?
Mar 4, 2010 at 2:30 AM
GREEZY2010
  • 6 POSTS
it sounds like the 4x4 is not disengageing all the way
Mar 4, 2010 at 2:37 AM
  • 110,244 POSTS
Two questions. Does it sound like the transfer case or the front axle that isn't disengaging? Also, have you checked the linkage to the transfer case?
Mar 4, 2010 at 3:49 AM
GREEZY2010
  • 6 POSTS
it sound as if the front axle is whinning when you shift out of 4x4 also when its in 4 wheel high the trucks seems to not want to pull correctly
Mar 10, 2010 at 3:04 AM
  • 110,244 POSTS
If the 4wd isn't disengaging, to me it sounds like one of the hubs isn't turning off. The front hubs are actuated by vacuum when you place it in 4wd. If the hub is dirty or damaged, it may engage and then not disengage. When you say it isn't pulling correctly, it makes me believe there is one side that is sticking.
Have that checked.
Mar 10, 2010 at 5:25 AM
