1995 Jeep Cherokee 2.5 turbo deisel
101,000 MILES • 4 CYL • 4WD • MANUAL
HUNTER88
My 1995 Jeep Cerokee 2.5 Turbo Deisel has been losing coolant through the expansion tank cap and has needed topping up with a litre about every 100 miles. The temperature gauge does not show it is getting hot. I recently topped the oil up as it was getting low and since then it chugs and produces a lot of blue smoke for a few minutes after starting. After that it runs fine. There is no oil in the coolant or water in the oil and the water hoses do not feel presurised.
Jan 29, 2010 at 1:02 AM
HUNTER88
[quote:c882af68d1="Hunter88"]Engine Mechanical problem
1995 Jeep Cherokee 4 cyl Four Wheel Drive Manual 101000 miles
My 1995 Jeep Cerokee 2.5 Turbo Deisel has been losing coolant through the expansion tank cap and has needed topping up with a litre about every 100 miles. The temperature gauge does not show it is getting hot. I recently topped the oil up as it was getting low and since then it chugs and produces a lot of blue smoke for a few minutes after starting. After that it runs fine. There is no oil in the coolant or water in the oil and the water hoses do not feel presurised.[/quote:c882af68d1]
Jan 29, 2010 at 1:25 AM
