1995 Jeep Cherokee
125,000 MILES • 6 CYL • 4WD • AUTOMATIC
FOOZN_DSM
Jeep will not start. Have an intermittent spark. Have changed ignition coil, distributor cap, rotor and camshaft position sensor. It will crank over. I seem to think it might have something to do with built in security, or it does have a remote start. I called the remote start co. they seem to think its not that. I recently purchased this car, and just found the remote start try,n to figure out the problem. The night before problems, I pushed wrong button on transmitter, the lights came on all around . I had only used transmitter for locks before. Im not sure how to reset the security system and/orremote starter, if that has anything to do with problem. What else and how could I check to see what it could be?
May 5, 2010 at 7:15 AM
  • 110,248 POSTS
Did you also replace the crank sensor? Does the vehicle have a factor alarm too?
May 20, 2010 at 4:36 AM
