1995 Jeep Cherokee
100,000 MILES • 6 CYL • AWD • AUTOMATIC
MARYENGLE
I don't really know the category. It will shut off with no warning, and won't start back for at least a few hours. It will then run for a few days ok, and then do the same thing again.
Apr 14, 2010 at 2:41 AM
INTERNETMECHANIC
  • 700 POSTS
Are you ready to do some testing? How long since a tune-up? Any applicable trouble codes? You should be able to access codes yourself, by cycling the ignition switch, on--off, on--off, on, you just cycle the key till the dash lites come , no further. the mil starts flashing, you count the flashes to get the codes, your looking for two digit codes.
When the problem occurs, if it cranks good but won't start, have a helper crank it, while you visually check for spark at the plugs. If you have spark everywhere, use a gage and check fuel pressure.
To check for spark, you can use a known good spark plug or spark tester, unplug spark plug boot, stick good plug/tester in boot, ground metal part of tester to metal part of engine, have helper crank, while you watch for spark.
Apr 14, 2010 at 7:16 AM
