1995 Jeep Cherokee
178,000 MILES • 6 CYL • 4WD • AUTOMATIC
JOHN H MILLER
  • 22 POSTS
how hard is to replace wiper turn signal switch with tilt wheel are the air bag a problem on this jeep or can you do the switch wihout touching air bag ?
Mar 20, 2010 at 8:27 AM
CRZYDRVR
  • 432 POSTS
I'm pretty sure that if were to remove the plastic cover around the steering column (right behind the wheel) you would be able to see that there are screws that hold it in place. I don't think wheel removal is necessary but if it is you will need to purchase some special tools for this. Your local auto parts store may be able to assist you on what you need.
Mar 21, 2010 at 12:21 AM
