1995 Grand Cherokee won't turn over & no Spark?
SPONNIE73
  • 1995 JEEP CHEROKEE
I have a 95 Jeep Grand Cherokee that will not turn over and does not have any spark at the coil. Has a new battery, all the lights work and are bright. When you turn the key all you get is some clicking noise coming from around the battery. 2 days ago the same thing happend, I put it drive and back into park and then it started but it won't start at all now. The coil checked out good with a ohm meter. Any help is greatly appreciated.
God Bless
Mike
Wednesday, October 11th, 2006 AT 8:49 AM
SFCARLOSS87NG
Hi, I had the same problem with my 94 MANY times, check the crank sensor in the transmision bell housing, and check the cam sensor in the distributor, both of mine went bad at different times, good luck
Wednesday, October 11th, 2006 AT 2:13 PM
CLARKPAUL
Ecm connector
Tuesday, December 28th, 2010 AT 11:11 PM
