1994 Jeep Cherokee Wheel bearings
1994 JEEP CHEROKEE
122,000 MILES • 6 CYL • 2WD • AUTOMATIC
FRANKLIN9523
1994 Grand Cherokee -
I'm trying to check the wheel bearings, but they are enclosed in a housing or hub of some kind, with no obvious way in. Does the hub go to a machine shop to be pulled apart, buy a new hub, what? I used to know how to do wheel bearings, but things have changed.
Jan 8, 2008 at 12:16 PM
BMRFIXIT
  • 19,053 POSTS
[quote:b3d064c9a8="franklin9523"]Suspension problem
1994 Jeep Cherokee 6 cyl Two Wheel Drive Automatic 122000 miles
I'm trying to check the wheel bearings, but they are enclosed in a housing or hub of some kind, with no obvious way in. Does the hub go to a machine shop to be pulled apart, buy a new hub, what? I used to know how to do wheel bearings, but things have changed.[/quote:b3d064c9a8]
Its a one unit
when you buy the bearing
they will sell you the hub assembly
it has 3 bolts on the back of it you need a 13MM socket 12 points
good luck
let me know
Jan 8, 2008 at 1:35 PM
