1994 Jeep Cherokee temperature gauge
150,000 MILES • 6 CYL • AWD • AUTOMATIC
DJVIP42
I have the v6 limited. I am noticing that my temp according to the gauge on the dash is running anywhere between the line after half to the 3/4 mark.. this is happening while i am driving on the highway and also city driving as well. Also my fan does not work on any speed.
(blower fan inside the truck) are the problems related? or is it normal for this vehicle to run at this temp?
thank you
May 11, 2009 at 2:11 AM
  • 110,248 POSTS
The temp should run around 200 degrees (around center). Chances are you need to replace the thermostat. As far as the blower motor. Many things could cause it not to work. You need to get to the motor (under passanger's side dash) and see if you are getting power to it. If you are, then the motor is bad.
Let me know what you find.
May 17, 2009 at 8:35 AM
