1994 Jeep Cherokee SPARK PLUG CABLE STARTS ENGINE
159,000 MILES • V8 • 4WD • AUTOMATIC
GUARDIANII
Jeep Grand Cherokee Limited starts when I test for spark by grounding a spark plug cable to the engine. Thereafter the engine will start fine and run fine. In the morning it will not strt. Again, I test for spark by grounding a spark plug cable to the engine. The engine starts and I can drive it intermittenly all day long, starting with no problems. The next morning, again it will not start. I do the same process over and over, day after day. What is wrong?
Jun 23, 2010 at 1:05 PM
  • 75,988 POSTS
Hi guardianii, Welcome to 2carpros and TY for the donation
If its getting spark all the time whether in the morning or not-check the fuel pressure if its within specs and get back with me with the readings we start here
Jun 23, 2010 at 1:55 PM
