1994 Jeep Cherokee replaced flexplate & tourque convert
200,000 MILES • 6 CYL • 4WD • AUTOMATIC
RJ100282
i replace the flexplate and torque converter in my jeep, hooked up all wires and it was running before but had to replace the flexplate and torque converter due to previous owner didn't install properly and damaged them. well anyways i tried to start the jeep and it turns over and chugs like it wants to start but don't. i've replace the neutral safty switch, the crank sensor, replace the spark plugs, spark plug wires, cap, rotor. anything else?
keep in mind it was running when i bought it with the broken parts.
Dec 22, 2009 at 2:46 PM
  • 31,937 POSTS
Hi there,
when the transmission was out was the engine hanging down against the fire wall? if so you may have unknowingly undone a sensor or a vacuum line, check all these things and run a scan just to check for any unresolved fault codes.
mark (mhpautos)
Dec 22, 2009 at 2:51 PM
