1994 Jeep Cherokee overheating
MND2005
  • 1994 JEEP CHEROKEE
  • 6 CYL
  • 183,000 MILES
My jeep has a new water pump and thermostat, the fan clutch and electric fan both work, but it still overheats, but only if im sitting at a light or in slow moving traffic. As long as im moving at a good pace or on the highway it wont get hot. Could it be a faulty thermostat or a clogged radiator, thanks for the help.
Tuesday, September 15th, 2009 AT 11:43 PM
If the radiator is not clogged and there's no air in the system, get it block and pressure tested
Wednesday, September 16th, 2009 AT 4:07 AM
CHULEGAARD
  • 35 POSTS
A lot of times it can be a cooling fan relay and the cooling fan won't turn on when supposed to
Thursday, October 22nd, 2009 AT 4:32 PM
Check and test the coolant temperature sensor this is the one that tells the computer to energize the fan relay
Thursday, October 22nd, 2009 AT 5:03 PM
