1994 Jeep Cherokee Oil Sending Unit
212,000 MILES • V8 • 4WD • AUTOMATIC
MARSHALL P
Recently the oil pressure gage shows a drop in oil pressure after warming up. No other indicators come on and the pressure drops to 0 after about 10 miles. The vehicle runs well with no other indications of a problem and I change the oil and filter regularly. I purchased an oil sending unit to verify the sending unit was not bad and I cannot find. Where is the oil sending unit on the engine and is it hard to replace?
Mar 29, 2008 at 11:36 PM
MERLIN2021
  • 17,250 POSTS
It's usually right next to or above the oilk filter...not real hard.
Mar 29, 2008 at 11:57 PM
BMRFIXIT
  • 19,053 POSTS
V8 engine on top rear of engine
almost near distributor
Mar 30, 2008 at 12:02 AM
BMRFIXIT
  • 19,053 POSTS
Hi Marshall P
I will try to get you some pictures but can you tell 1st
is it a v8
or 6 cylinders
and is it Cherokee
or grand Cherokee
because I don’t think Cherokee had V8
jack
Mar 30, 2008 at 12:52 AM
BMRFIXIT
  • 19,053 POSTS
to answer u r Email
on V8 G.Cherokee
its in the rear by the fire wall
beside the distributor.
u may need a special socket
check the new one
Mar 31, 2008 at 11:09 AM
BMRFIXIT
  • 19,053 POSTS
Jack, I have looked all around the distributor and can find nothing, but as a reminder, there are so many hoses and cables, I cannot be sure just what is what. The distributor sits so close to the firewall, there is no room to do much of anything. Thanks for the help and I appreciate anything you might find. Marshall HI Marshall this is what i found so far hope that will help Jack
https://images.2carpros.com/forum/automotive_pictures/99387_jeepoil_1.jpg
Apr 1, 2008 at 12:44 PM
