Cod e55 end of message no codes
pull and check for spark try and listen if you hear the fuel pump when 1st key on
locate ASD relay mark it and switch it with another similar relay
check coil
turn key on do you have check engine light on?
If not check fuses and relays
if yes crank engine light should go out as cranking
if not I would check and replace crank sensor
check if you have any security light on or blinking with key in the ignition and on
good luck and let me know
Tuesday, January 27th, 2009 AT 7:02 PM
