1994 Jeep Cherokee iignition switch
BISMARK828
  • 1994 JEEP CHEROKEE
  • 6 CYL
  • 4WD
  • 164,000 MILES
Jeep starts but when I release key the engine stops--just had aproblem with dead battery-replaced battery then this happened--iwith key on all accec work--if I hold key in start pos --engine runs but noaccesorys-everything thing points to ign swich on col--but I am not sure-jeep runs fine if I hold key in start pos
Monday, January 19th, 2009 AT 7:55 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Check the ignition switch and the coil resistor, if equipped. When the starter is engaged there is a direct connection to the coil. The intention is to give the coil a little more voltage when the starter is engaged. If the ignition switch isn't connecting properly, it won't run when you release the starter. If your vehicle uses a coil resistor you might get the same results from defective coil resistor.
Thanks for using 2CarPros. Com!
Monday, January 19th, 2009 AT 8:15 PM
