HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Jeep
Cherokee
Climate Control
Heater
1994 Jeep Cherokee heater resister
NISMO99
MEMBER
1994 JEEP CHEROKEE
6 CYL
2WD
AUTOMATIC
144,657 MILES
Where can I find it in my jeep
Saturday, January 23rd, 2010 AT 5:58 PM
BLUELIGHTNIN6
MECHANIC
Under the dash on the passenger side of the vehicle, against the front firewall there is a black plastic panel held in place by two scews. Remove this panel and the blower motor resistor will be found.
SPONSORED LINKS
Saturday, January 23rd, 2010 AT 7:04 PM
Please
login
or
register
to post a reply.
Related Heater Content
Heater Dont Blow
94 Jeep Cheokee Country Heat Only Blows On Low I Do I Fix It?
Asked by
vkredding
1994
JEEP CHEROKEE
GUIDE
Heater
Once the engine has been started and has run long enough to warm up the hot coolant is transferred into the heater core which is located inside the passenger compartment via...
1999 Jeep Cherokee Heater Settings
Alll The Heater Settings And Fan Settings Work Except The Defrost Setting That Setting Will Only Blow Out Very Little Air Regadeless Of The...
Asked by
ljhopp
1999
JEEP CHEROKEE
2001 Jeep Cherokee Heater Repair
I Need To Replace The Heater Actuator Which Controls The Air Flow To Various Ducts For Heat/air Mix. Is There A Manual For Taking Apart The...
Asked by
captardy
2001
JEEP CHEROKEE
1998 Jeep Cherokee When I Put The Heater On The...
When I Put The Heater On The Vehicle Stalls? Will Run Good When The Heater Is In Off Position
Asked by
ruppev
1 ANSWER
1998
JEEP CHEROKEE
2002 Jeep Cherokee Steam Coming From Heater On...
When I Have My Heater On Steam Comes Out From Under The Front Of The Hood. It Does Not Affect The Heat But It Gets Embarressing To Pull Up...
Asked by
mary65alice
1 ANSWER
2002
JEEP CHEROKEE
VIEW MORE
SPONSORED LINKS
Heater Not Working
Heater Not Working
Blend Door Actuator Replacement
Online car repair manuals
