1994 Jeep Cherokee Heater blower
PCJEEP
1994 Jeep Cherokee
when I shut the engine off to my 1994 Jeep Cherokee, the internal heater fan continues to blow. I believe it is a stuck relay...If this is a correct assumption, where is the relay located?
Apr 2, 2009 at 4:16 AM
JDL
  • 16,098 POSTS
https://images.2carpros.com/forum/automotive_pictures/170934_blower_resistor_5.jpg
Hello, I don't know how accurate the picture, all I could find. If you want to track the problem start at the blower resistor. If you just want to stop the blower, pull the fuse. There is a blower motor switch for the speeds, you may have to check there. The picture came from autozone.
Apr 2, 2009 at 5:08 AM
PCJEEP
thank you for your reply jdl123...for now I just unplugged the electrical conn...thanks again for your help.
Apr 2, 2009 at 5:45 AM
