1994 Jeep Cherokee head bolt sequence
167,000 MILES • 6 CYL • 4WD • AUTOMATIC
BLSC309
I am trying to find out the proper sequence and specs for tightening the head bolts.
Sep 15, 2010 at 5:58 AM
SATURNTECH9
  • 30,869 POSTS
2. Position the engine cylinder head gasket (with the numbers facing up) onto the cylinder block. CAUTION: Engine cylinder head bolts should be reused only once. Replace the head bolts if they were used before or it they have a paint dab on the top of the bolt. Fig. 6 Engine Cylinder Head Assembly 3. With bolt # 14 held in place (tape around bolt), install the engine cylinder head. Remove the tape from bolt # 14. 4. Coat the threads of stud bolt # 11 with Loctite (TM) 592 sealant, or equivalent. Fig. 7 Engine Cylinder Head Bolt Tightening Sequence 5. Tighten the engine cylinder head bolts in sequence according to the following procedure Fig. 7 : 1. Tighten all bolts in sequence (1 through 14) to 30 N.m (22 ft. lbs.) torque. 2. Tighten all bolts in sequence (# 1 through 14) to 61 N.m (45 ft. lbs.) torque. 3. Check all bolts to verify they are set to 61 N.m (45 ft. lbs.) torque. 4. Tighten bolts (in sequence): o Bolts # 1 through 10 to 149 N.m (110 ft. lbs.) torque. o Bolt # 11 to 13 N.m (100 ft. lbs.) torque. o Bolts # 12 through 14 to 149 N.m (110 ft. lbs.) torque. CAUTION: During the final tightening sequence, bolt # 11 will be tightened to a lower torque than the rest of the bolts. DO NOT overtighten bolt # 11. 5. Check all bolts in sequence to verify the correct torque. 6. If not already done, clean and mark each bolt with a dab of paint after tightening. Should you encounter bolts which were painted in an earlier service operation, replace them.
https://images.2carpros.com/forum/automotive_pictures/416332_1994_jeep_cherokee_head_bolts_tightening_1.jpg
There you go.
Sep 15, 2010 at 6:54 AM
