1994 Jeep Cherokee Alternator/Battery
183,000 MILES • V8 • AWD • AUTOMATIC
JLOWERY24
I tested the battery and the battery tested good; the alternator is charging the battery from anywhere between 10.3 and 12 amps/volts, is this low enough for the alternator to be bad or could it be a fuse or something else?
Dec 23, 2009 at 5:34 PM
BLUELIGHTNIN6
  • 16,542 POSTS
that is weak, you need to test alternator. most auto part stores will test the alternator for you, free of charge on or off of vehicle.
Dec 24, 2009 at 10:21 AM
