1994 Jeep Cherokee 94 Jeep Grand Cherokee leaking radiator
1994 JEEP CHEROKEE
250,000 MILES • V8 • 4WD • AUTOMATIC
NOVALAWHP
how do you know if its the water pump,radiator, or themostat? Also what would cause the radiator not to pull from the resavoir if it needs more fluid?
Dec 31, 2007 at 1:29 PM
  • CAR REPAIR CONTRIBUTOR
Also what would cause the radiator not to pull from the resavoir if it needs more fluid? Defective radiator cap.
For the others-fill the radiator till its about 3/4 from the opening leave the cap off-start the vehicle do you see the coolant swirling around-now pinch the upper hose for a few secs-let go do you see increase of flow if not the pump is not doing its job
Dec 31, 2007 at 5:42 PM
