1993 Jeep Cherokee Why Would It Turn Over But Not Start
CABOOSE253253
  • 1993 JEEP CHEROKEE
  • 6 CYL
  • 4WD
  • 10,000 MILES
We have been working on this for a month but could not find a solution. We checked and replaced allot of parts but still wont work
Wednesday, August 12th, 2009 AT 6:05 PM
Do below and comeback with some results
Get a starting fluid/ether/better off gas in a spray bottle and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor /distributor pick-up coil, ignition control module, ECM, Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems with compression and valves opening and closing at the wrong time/broken or jumped timing belt/chain
Wednesday, August 12th, 2009 AT 7:06 PM
