1993 Jeep Cherokee replacing cam shaft
150,500 MILES • 4 CYL • 2WD • MANUAL
LESTERSDAN
I am a home mechanic and am replacing my cam shaft.
I am following a detailed removal/installation printout given me by my local repair shop.
I don't have air tools. I am having a problem removing the bolt holding the harmonic balancer. I cannot break the bolt free using a regular socket. When I try to loosen the bolt, the crank turns.
I am told that I can hold the flywheel with an approved tool and I should be able to free the bolt.
Any other suggestions, I don't want to damage the flywheel.
Nov 20, 2009 at 12:40 PM
  • 110,248 POSTS
Actually, I usually place a breaker bar on it and then wack it with a dead blow hammar. After 3 or 4 good hits, it comes loose.
Let me know if it helps.
Nov 27, 2009 at 6:34 PM
