1993 Jeep Cherokee 6 cyl Two Wheel Drive Automatic
How to replace the Postive side battery cable
Feb 24, 2009 at 4:43 AM
BLUELIGHTNIN6
✓Experienced Mechanic
Disconnect both cables from battery and set battery aside. Disconnect cable from starter solenoid and remove cable. Replace with new cable and reconnect positive battery cable at both ends along with the negative battery cable to the terminal.
