1993 Jeep Cherokee oil manifold
1993 JEEP CHEROKEE
200,000 MILES • 6 CYL • AWD • AUTOMATIC
KDDOWDLE
I need to change my O-rings on the oil manifold the part that holds the oil filter and oil sending unit. How do i remove the whole unit to change the O-rings?
Dec 14, 2008 at 12:16 PM
TGFISHEL
  • 52 POSTS
drain the oil . remove filter . unhook oil sending unit. unbolt manifold . replace o-rings then reinstall every thing . make sure you torque the bolts to spec.
Dec 16, 2008 at 10:43 AM
