1993 Jeep Cherokee gas tank problems
140,000 MILES • 6 CYL • 4WD • AUTOMATIC
SHANNON1973
fuel pump was replaced a few weeks ago since then every time i try to put gas in it leaks out and the gas pump is constantly shutting itself off before i am done
Apr 3, 2008 at 1:47 PM
BLACKOP555
  • 10,386 POSTS
sounds like the vapor line or the fuel filler line wasnt hooked up properly, the check valve may be bad also, or unlikely but possible the carbon can may be bad.
Apr 3, 2008 at 3:21 PM
