1993 Jeep Cherokee fuel to injectors
130,000 MILES • V8 • 4WD • AUTOMATIC
98BIGDADDY
Is there a sensor that controls fuel to injectors cuz i have changed fuel filter drop tank fuel pump working turn key it cranks but still haveing issues with getting fuel a lilttle help thanks
Sep 5, 2009 at 9:21 AM
  • 75,988 POSTS
If the fuel pump is producing the correct fuel pressure and the injectors are pulsing you should have fuel in the cylinders.
If not check for power on the injector dark green and orange wire do you have it and if its not pulsing possibly the ground drivers in the computer-
Sep 5, 2009 at 9:41 AM
