1993 Jeep Cherokee Clutch fading
1993 JEEP CHEROKEE
207,000 MILES • 4 CYL • 4WD • MANUAL
RBROWN447
I think may slave cylinder is leaking, Can I bleed the clutch for now and get some clutch back until I replace clutch and slave cylinder? If so were is the bleeder valve located?
-Russ
Dec 16, 2008 at 6:22 AM
If its leaking its useless to bleed it-you need to replace whatever is leaking before you can have pressure.
Dec 16, 2008 at 6:28 AM
