1992 Jeep Cherokee water pump replacement
MAMOWDOT
  • 1992 JEEP CHEROKEE
Engine Cooling problem
1992 Jeep Cherokee 6 cyl Four Wheel Drive Automatic
cant seem to find out how to release tension on serp. Belt
Saturday, June 6th, 2009 AT 5:37 PM
  • 109,896 POSTS
This doesn't have an automatic tensionier. Standing center in front of the car, look down slightly to the right. I believe it is on the power steering pump. You will need to loosten the set nut on the adjuster then there is a bolt that when loostened will loosten the belt. I believe it is a 13mm. Here is a diagram of the system with AC. I believe if you look at the 4.0L pulleys, it's on number 3.
Let me know if this helps.
Saturday, June 6th, 2009 AT 11:13 PM
